Not trading in for a 4x4
I had three at last count including the lawnmower, two of which are road legal including the lawnmower
4X4 count now at 4
tour of a modifed unimog 404
I bought a MOG
A unimog 404s 1975 vintage
Pics?
Okay here it is with one wheel on the trailer and it still has loads of flex left.
This is the rather simple but hugely effective suspension system. The big tube down the middle isn't a drive shaft it is the torque tube. It goes into a large ball joint at the back of the gearbox and that allows the whole rear suspension to pivot around the ball. There is a panhard rod at the back to stop the axle floating about. The actualy driveshaft runs inside the torque tube which keeps it out of harms way. If you look backwards you can see the portal drop boxes which mean the center of the axle line is not the center of the wheel
The front suspension which are also portal and you can see the massive CV joint which goes into the drop box.
This shows the ground clearance which big wheels and portals have when compared to a landrover.
A 17" alloy off the wifes Honda to give a an idea of the wheel size.
The side of the tyre sayes 335/80R20
The luxurious cab with lots of levers
The two at the furtherest away with no ends are the 4x4 and difflock levers
The next one with a small lever attached is the handbrake
The big one with a knob on it is the main gear selector which has 2 low and 4 high gears. It can be modified to give you 4 low and 4 high.
The little on is the forward/reverse selector which only works in the low gears but you do have low 1st and 2nd in reverse if you do the 8spd mod then you have low first 2nd, 3rd and fourth in reverse.
Climbing stuff which is what it does really well
it cost me 2 grand which was a bit of a bargain but similar can be picked up in the UK for less then 3K it is kind of boring offroad as where a landrover would have difficulty this wanders through without any hassle. The only time i have got stopped is deep mud but i just reversed and charged and got through. Also the way it is built is fantastic. my landrover is 12 years old and has already big patches on the chassis the Unimog is 36 years old and the chassis is as good as the day it left the factory
