Hi folks!
I purchased a set of rear top adjustable rods for my Accord and got them fitted today...then taken back off again.
The ball joint on the adjustable rods
do not pivot enough to allow a safe clearance / movement.
To fix the problem i would have to modify...the modified part. Work that out! The ball joint would need to have a kink in it to allow free movement.
The standard ball joint HAS BETTER MOVEMENT...around a 2mm gap. It is safe to drive on standard rod as there is a constant 2mm gap.
Has ANYONE lowered their Accord more than normal and may have come accross this problem before?
And, is there anything else i can do / purchase that would solve problem?
Pictures below;
STANDARD ROD
HEELTOE ROD
HAS BEEN RAISED SLIGHTLY SINCE THIS PIC WAS TAKEN. TRYING TO GET REAR CAMBER RIGHT....
