Rear wiper problem
gazT
Leeds
Honda accord ex-ctdi
As ***le suggest my rear wiper has stopped working, checked fuses which are fine, bought a replacement motor and installed but still not working. Is there a relay for the rear wiper, if so where is it? or do I need to replace wiper stalk/switch. Any advice, please.
I suggest honda hds as with that you could have tested rear wiper before buying a replacement motor as that would verify wiring and motor is working.
Cheers for that, but has anybody got any info regards a relay or it just fuses and a stalk switch where any problems may be.
The fuses are under the dash and there is a relay not sure on location.
Check that and then crack the multimeter out.
Relays are under dash you will have to follow from switch
***uming this is a 7th gen tourer? More likely a broken wire in the loom where it hinges.
i would agree and hds would have eliminated the relays and motor leaving just wiring and switch.
