I've recently visited Fahad and got a stage one map with EGR delete which I'm very happy with. Unfortunately my clutch isn't so happy and I noticed it slipping for the first time today under hard acceleration.
Under normal driving conditions like up to 2/3 or 3/4 throttle even around peak torque it is fine. But, it is undoubtedly slipping by a few hundred rpm, mostly in third and fourth when using full throttle. The biting point was fairly high beforehand so I guess it was nearing the end of its useful life anyway - a little disappointing considering it has only done just over 50,000 miles. This will be the first clutch i've ever had to replace even though I've owned a number or petrol and diesel turbo charged cars.
At least the DMF seems fine at the moment!
I'm not too keen on being ripped off by a main dealer and I have a trusted independent garage just down the road from me. So the question is, what clutch should I go for?
EuroCarparts does an LUK clutch kit for £125 Linky
Is it worth going for a like for like replacement or am I going to be sorely disappointed 20,000 miles later when I have to replace it again?
I understand some people have gone for a CG motorsport clutch and DMF however Leeds is a little far for me to travel unless there are exceptional circumstances. What other clutches do pepole recommend for remapped I-cdti's?
Thanks in advance for your help!
