-Rich-
Yesterday the engine was cranking but wouldn't start. I tried several times and I suspected the battery was a bit flat so I charged it up last night and tried again this morning. It still didn't start but was cranking ok so I don't think it is the battery, plus it's not even 3 years old yet. The positive clamp is a little loose as it won't tighten any more so I need to get a shim for it but I don't think that's causing the problem.
I checked the fuse box and made sure all the relays and fuses were seated ok then I tried again while pressing the throttle. I managed to get it started and let the engine run for 5 minutes before turning it off. It was ticking over as it should.
I'm suspecting it might be fuel related - maybe a relay, the pump or just a blockage. Any ideas on what I can check and how to test them?
