Hengist
Went to change my front strut top bushes at the weekend, and discovered that on both sides the metal sleeve that goes through the middle of the two rubber bushes (# 16 in below Lings pic) appear to have rusted solid onto the spindle (i.e. the top bit of the shocker).
Also, #10 - the metal plate - is either rusted onto the metal dust cover piece #13, or it's not there.
I had to put the car back together to use, so liberally greased around the rubber bushes where they contact the metal sleeve and lower metal plate (#10).
So - looking for advice. Does it matter that the metal sleeves are rusted on, or should I take it all apart again and attempt to remove them and replace with the new ones that came with the bushing kit?
I'm thinking that the strut-top spindle should probably move freely inside the sleeve, but would it make that much difference? My handling is improved as it is now, but still not perfect.
