Stuc Pattern
MeatyChi
N.Yorkshire
Accord 2.2 CDTi
Morning all,
OOps that meant to say stud pattern!
Can someone tell me if the stud pattern on modern civic/accords the same??
If I purchased a set of 17s for a 57 Civic would they fit my 54 Accord?
Should be fine... what abotu the bore size?
There is a recent thread - have a quick search for PCD
Yes 5x114.3 and ET55 offset. Bore of 64.1mm is the same. Just check tyre sizes.
Morning all,
I think you should be fine. The latest gen Civic's on 17" rims should run the same 225/45/17. Just make sure the load index is either 91 or 94 and the speed rating is Y (although I think you will get away ith W)
