Hi....I got my 7th Gen Accord 2nd hand and noticed that the passenger side seat heating switch is not illuminated when the lights are switched on....Is this a simple job of bulb replacement or do i have to change the whole switch?
its a bit tricky but not to bad.
Im sure you need to take the gater from the gear stick then take out the ash tray to unclip the surround.
If you can't find a diy look at things like removeing the dvd drive this will give you an idea
