Dangil
I wonder if someone can help me, i'm in the process of checking the clearance of the tappets. My query is about the right hand side intake rocker arm, its got a spring loaded timing plate pushing it down.
Do you adjust the clearance so you over come the pressure of the timing plate so the rocker arm touches the cam lobe base or do you adjust it, so its within spec without moving the timing plate?
The engine is an F18B2.
