The problem with the lambda probe
Bacho
Poland
Honda Accord VI
Hello. In Poland, no one can help me :( I changed my Accord VI engine from 2.0 to 2.3 F20B6 F23Z5, the driver also has been changed to one with 2.3, but the loom was of 2.0. Was it my fault that I left the old electrical harness? No work for me the first lambda probe, lit an error or mistake 41 heater probe. is the wiring is different engines 2.0 and 2.3? Does anyone might wiring diagrams of the two engines?
If the Lambda isn't working then you probably need one off from a 2.3 model.
Are you using the same lambda sensor that was on 2.0 engine? If you are then you probably need to use one for 2.3 engine.
I highly doubt a universal lambda will work, these cars are extremely fussy with what o2 sensor you put in, some brands won't work at all, NGK is the right brand but I dont know what model you need for the F23, sometimes nothing will work apart from OEM sensor, it can a draw of luck with them.
Not sure, you can have a look on lingshondaparts website and see if part numbers match up for o2 sensor on 1.8, 2.0 and 2.3 engine
as above, try comparing the parts for the two cars that you have
start here https://www.lingshondaparts.com/honda_car_parts_catalogue_C01.php
when you get to the parts list for any section, you will see that the part numbers begin with "PFKL", which are not Honda numbers. To get Honda numbers, remove "_pfk" from the url of the page.
I have removed "_pfk" for the exhaust system sections for the 2.3, 2.0, and 1.8
https://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=17S4A11&block_02=B__0200&block_03=6914&block_05=hcr
https://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=17S4A11&block_02=B__0200&block_03=6906&block_05=hcr
https://www.lingshondaparts.com/honda_car_parts_selection.php?block_01=17S4A11&block_02=B__0200&block_03=6900&block_05=hcr
strangely, 2.3 and 1.8 look the same part numbers, but 2.0 does not, but you ought to check it yourself to be sure
me people in Poland forum Accord also say the Lambda 1.8 and 2.3 is the same , 2.0, is different .
