Don't worry too much about using the car in the short term,  the chains will get incredibly noisy and this will go on for a long time before they fail,   but if its getting louder now in such a short period of time,  1. your listing to it too much,  and 2. its time to think about replacing them
The febi chains are fine,  if you can get them for £100 then that's a bargain,  I would also replace the tensioners without doubt,  Honda only supply the newer type, this helps prevent future problems with the new chains, they are a free floating tensioner rather than a ratcheting type .  As for the guides,   there are two,  there are the tensioner "Shoes" which is what the tensioner acts upon to tension the chain.   and the black plastic guides which the chains run in,   the black plastic guides don't cause problems,  but inspect them for deep grooves and pitting,  there will clearly be groves in these, but if its not deep and pitted, don't worry.   The tensioner shoes are an aluminum arm with a brown/orange plastic runner,  these tend to get a groove cut into the lower impact surface,  again,  minor signs of a groove is normal, but if they are cut into or pitted by the chain,  for the sake of a few quid, replace them.
I get asked a lot about the sprockets,  if your engine has low miles <50k miles on it,  the sprockets should be replaced as this means the engine has suffers from a "known fault" which is related to carbon in the oil and the sprockets and chain wear against each other,   if its done a fair few more miles its clearly not suffered from this problem and the sprockets should be OK,   its general wear and tear on the chain its self in which case sprockets are not needed,   but ultimately its best to replace everything to guarantee a trouble free future,  realistically,  the sprockets never cause issues.
I hope this gives you a bit of help, feel free to let me know if you need any more help with it,   i have been there main times!!!
