Thanks Nicola,
I will keep in mind what you say about tightening the injector bolts. And please do list the parts needed if you have time.
To All,
Today being Saturday I had some time to work on my car:
The
short story is that I got all the oil pan bolts out, and removed the cam chain cover to inspect the damage. The cam chain was totally loose and the bigger guide is smashed to pieces. But the oil pump chain is tight. See photos:
http://s53.photobucket.com/user/tim559011/library/?sort=3&page=1
The longer story,
with questions, is as follows;
Most of the oil pan bolts were easy enough, once I'd found them, bearing in mind I am doing this job on my back under the car. One of the 14mm (head size) bolts going into the clutch bell housing tightened as I undid it, and I had to coax it all the way out, bit by bit. This was the bolt nearest the front of the car. Once it was out I saw it had stripped about 8mm of the internal thread, but luckily the hole for it goes all the way through the bell housing so I think I'll just get a slightly longer bolt and there will be enough thread there to tighten it properly. The other bolt I had trouble with (in case this is useful to anyone else) was the lower, more central, bolt for the air con pump. I was terrified this would snap off as it wasn't budging when I applied quite a bit of pressure with a 1/2" rachet. So I left it, undid the other three, and went back to it from a different angle and this time it came loose in a normal way. If an inaccessible bolt had broken that would have scuppered the project for me as I don't have facilities for drilling out broken threads. I don't know what professional mechanics do when bolts snap, it must happen, in horribly inaccessible places ??? So, it took me about 2 hours to get all the oil pan bolts undone; Holy Moley, you might say, but I was glad to not be in a hurry and to get them out without any breaking.
Question: will the oil pan slide out now that I have removed the 2 rear mounting bracket bolts and the AC pump bracket bolts? Both brackets still press against the oil pan; I don't know if this will be a problem.
Taking the cam chain cover off was then pretty easy as I had undone all the bolts previously and I only had to take off the upper engine mounting bracket, which I had also done before and temporarily replaced. Luckily, as I said above, with the cover removed I could see that the oil chain was tight, in fact it is totally tight, no deflection in it whatsoever, on either side; I suppose that means the tensioner is doing its job? I tried gently levering the chain away from the sprocket at the top and there is maybe 1.5mm of movement, very little. However I do plan to replace the oil pump chain, and tensioner.
The cam chain, as I said, was totally slack. I had previously removed the tensioner through the little inspection hatch. The front chain guide is broken and the 4" middle section was lying loose in the sump. See photo of broken parts.Various bits of the orange plastic guide were scattered about, in many pieces. There is some minor damage to the casing on the engine side, hardly visible in the dark photo, and slightly greater damage to the chain casing cover, visible in one of the photos. I think both are acceptable, I will just file the edges smooth. There is a large circular blanking cap on the engine side, mid way up towards the front, which is partly worn away but not broken. I have no way of knowing if the chain has slipped on either the crankshaft or cam shaft sprockets.
Depending on advice given on this forum I will decide whether to go ahead and buy the new parts. At the moment I think I will, even though I can foresee possible difficulties clearing fault codes and getting the engine started.
Some of the bolts were ridiculously challenging to get at today, but I guess in theory if I have dismantled it I should be able to ***emble it. I have this forum as a resource and I have bought the Civic manual which details this engine.
All help welcome!
Thanks, Tim M
