Correct also any timing position sensors will cause vsa to not work you need to follow procedure in manual for error codes if error codes keep staying on fault is presentJ_VTEC said:Ok. So I'm driving the car today and the engine check light comes on.
Wondering if the crank sensor needs replacing. I think the traction control uses this to monitor engine RPMs. If the sensor isn't functioning, neither will the traction control and subsequently the VSA.
Just a hunch
