s-preston87
Hi guys,
I think my third gear synchro is starting to go, I had my clutch replaced when the car was purchased and had the transmission fluid replaced with Honda MTF.
Due to financial circumstances I can not afford to pay for the transmission to be taken out again, cracked open to then inspect the synchro's.
I have been doing a lot of research on the GM synchromech friction modified > now know as AC Delco synchromesh friction modified, apparently helps to smooth out gear changes and help protect already warn synchros etc. Before the abuse starts lol I am fully aware that it is only masking the problem, this will ONLY be a temporary solution.
Many many reviews from USA and even in the UK high recommend it, but has anyone here used it before?
Any help, advise, links etc would be much appreciated.
cheers ^_^
https://www.amazon.com/ACDelco-10-4014-Friction-Synchromesh-Transmission/dp/B0026JK8FK
(BTW: Driving a 2005 Accord Sport PETROL)
cheers ^_^
