Hi all. Having some problems with my accord (04, 2.4 type s).
I've had an ongoing problem with this for a while but it is very intermittent. The radio would go off and on, lights would all flicker, car wouldn't want to start etc. I initially got a new battery and alternator but it is still happening. I think I've narrowed it down to the ground cable of the negative battery terminal.
The bolt which attaches to the metal body of the car just will not tighten, it just spins. This means that it comes loose every so often, giving me issues until I push it back in.
The lead is also looking a bit worse for wear with exposed wiring so it might need replacing too.
Can anyone shed any light on this? Either if it looks like the lead needs replaced, or how I can stop this bolt popping out?
Much appreciated!
Much appreciated!
