mutsaip
For some months now VSA light had been coming on intermittently and gradually much more frequent, until the ABS warning light decided to join in the fun. So it was off to the dealer who diagnosed it as the right rear brake sensor which was then replaced. The lights (ABS & VSA) were no longer showing when I picked up the car from the garage. A few miles of driving shortly afterwards, the VSA light came on again. I took the car back and this time they said the VSA module (£1800) was the cause and would need replacing. This news was hard to swallow, but through this forum my understanding was these units (petrol version) have never been known to fail.
Fortunately, Discodave kindly advised me to check the brake light switch and clean the contacts points as this could be the likely cause of the VSA light coming on. I did this but it didn't seem to do the trick. Every time I used the brakes after starting, the VSA light popped up- the switch was now clearly the culprit. I also noticed that the brake lights were working properly too, and the cruise control was virtually dead.
I bought a brand new brake light switch (£40) from a Honda dealership and fitted it myself, result - no VSA light, brake lights and cruise control all working again. I went out for a drive with no problems for now, so I hope it stays that way. Pleased??...for sure I am now that I don't have to shell out £1800
Discodave pointed out that this was a known problem: http://tsx.acurazine.com/forums/showthread.php?t=686501 . Thanx for sharing that Dave.
This is the culprit: http://i1231.photobucket.com/albums/ee505/Muts_Aii/STP60441.jpg
