waj1974
Guys, was driving today and the vsa triangle started flashing on my dash and the abs started to kick in, scarry moment, but after a while it went away....anyone experienced this before???
I hate to say this but the night before my VSA was shot with code 66.1 this was very similar what mine did.It did this around a roundabout then was fine.I got in the car in the morning and the VSA was on all the time.Guys, was driving today and the vsa triangle started flashing on my dash and the abs started to kick in, scarry moment, but after a while it went away....anyone experienced this before???
Im not sure the mate of mine had a very expensive snap on one.If you have a code 66.1 the VSA light will be on permanent.dos the 66.1 code show up on a regular obd code system, or the hds?
Waj what scanner are you usingNo Codes dan
This is odd im just guessing but it might be an intermittent fault but i would have said there would have been a fault code.It's an obd 2 scanner cost me 60 quid scanner, no permanent vsa light and I've driven the car for a while and still nothing...
Then i would say its an intermittent fault with a abs sensor.When you had the new tyres the guys might have knocked the sensor so it could be just a loose connection but see what others think 1st.Good link bret mine happened when I was going round a bend, abs kicked in I wasn't braking...
