Hello all! I’m having some difficulty with a leak on my Honda. I have a 98 Honda Accord 1.8i ls. Yes, it has a sunroof but I don’t believe it to be the problem.
I am getting water in the trunk and the rear passenger footwell. I took it to a shop and they said that it was coming in from the windscreen. So, I had a windscreen shop seal the entire bottom of it. However, I am unable to test to see if it is still leaking because when I press my hand on the carpet in the rear footwell, I can hear water sloshing around. When I press my finger down by the mount, I can see water coming in. Is there an *easy* way to drain the footwell?
As for the trunk, The water seemed to be coming in from the sides of it because both side carpets were wet. I had the same shop try to reseal light seals in the trunk. I haven’t had water come in the trunk yet, but I wanted to see if it was all connected. Have any of you had this issue and where was the leak? And what did you do to fix it? Any advice is much appreciate. I’m attaching pictures of where the water is. Thanks!
Note: I’m very visual so if you have advice
