Fredoops
It's not a proper comparison run, it's just 2 runs hurriedly thrown together in the middle of a dyno day., the car didn't even came down from the roller.
None the less the bump is clearly there, a 18 horse power bump where the VTEC is engaged.
I need to check the TPS voltages, throttle body may be playing up causing the flat line up the end of the rev range...or something.
Want to do a proper comparison you do 2 runs each tune at least and actually properly install and reset both the ecu instead of just plug and go in the middle of it all.
What we had here is a Reflash with fuel trim vs OEM with no trim, whether that matters or not is up to debate, but none the less it's a control.
Just to make sure your ECU's WOT compensation values is actually same, otherwise you might as well go home.
A proper comparison would involve the both ECU's been reset then let sit idle to update the trim, THEN you dyno the damned thing.
