toffee_pie said:
getting 220hp or thereabout on a stock k24 is very tempting and the killer is shifting the vtec biting point to what it used to be in the good olde days of vtec. more hp, proper vtec and more torque, whats not to 'like' ?
DO NOT BELIEVE ANY NUMBERS ON ROLLING-ROAD DYNO GRAPHS THAT CLAIM TO SHOW BHP AT THE ENGINE. IT IS TOTALLY IMPOSSIBLE TO INFER ENGINE BHP FROM A ROLLING ROAD DYNO. REPEAT, IT IS TOTALLY IMPOSSIBLE TO INFER ENGINE BHP FROM A ROLLING ROAD DYNO.
Apart from Fahad and myself, I don't think there is anyone else in this forum who understands this. Yet it is very simple.
Let's say that an engine is measured in a test-bed, with its ancilliary equipment installed (that's the stuff on the pulleys Eric), and the max it produces at WOT is E BHP coming from the end of the crankshaft.
The engine is then put into a car and measured on a rolling road (at the wheels).
The power at the wheels is less, let's call it W BHP max at WOT.
So E - W is the power lost, but where ??
Some, G, is lost in the gearbox (if you go to Germany and drive at 140 mph then stop the car, the gearbox will be too hot to touch).
Some, D, is lost in the driveshafts and CV joints (if you go to Germany and drive at 140 mph then stop the car, the driveshafts and CV joints will be too hot to touch).
A lot, T, is lost in the tyres (if you go to Germany and drive at 140 mph then stop the car, the tyres will be too hot to touch).
When you measure W on a rolling road, you don't actually know what T is, nor G, nor D. So you cannot infer E, which you will never know unless you take the engine out of the car.
Let's go back to what I said in post #62. Between 5000 rpm and 7200 rpm, there is an AVERAGE increase in torque of 17 Nm. For the sake of what we want to know here, it does not matter whether this was measured at the end of the crankshaft or on a rolling road, it is the RELATIVE difference measured in the same car on the same equipment on the same day, that we want to know.
For the increase in top-end BHP, things get complicated. If you look at the graph in #54 (presently #55 because of something Steve has done with the thread), you will see that the plots almost touch at 7200. But, with the reflash, you get an extra 400 rpm.
7600 is about 5% up on 7200, and because the torque is not dropping away like a lemming over a cliff, then this represents a useful increase of time spent in each lower gear. As you reach the rev limit, you have to change up, which is a massive drop of torque at the wheels. So on its own, as long as the torque is not dropping away like a lemming over a cliff, a 5% increase in rev limit is equivalent to a 5% increase in BHP.
But note also on that graph, someone is claiming from a rolling road that the new BHP is 226, but if you look at the plot below, it peaks at 215 BHP. So what engine was it, that allegedly gave 215 BHP from the engine before a reflash ???
(I call bunkum)
To conclude: Eric, no-one has said that you will get 226 BHP from your engine after a reflash. Be very very very very very very very careful when looking at dyno plots. Forget the big numbers, forget the plots that show engine torque or engine BHP. The only plots that are useful are either 1. torque or power at the wheels, or 2. comparative or back-to-back plots.
Dyno plots are not about "subjectivity" or "calibration", they're about common-sense engineering. It's a black-and-white issue: they're either usable, or not usable. Where they fall Into the latter case, they're a waste of paper and ink in the real world, or a waste of electrons in the internet world. Where they fall into the former case, if you don't understand everything I've typed here, they might as well be in the latter case.
