2.2 DTEC EGR VALVE
G.aw78
CRV 2.2 DTEC EX AUTO
Has anyone replaced/cleaned the EGR valve on the 2.2 DTEC engine? It looks like an absolute c*nt of a job. Can it be done from the top or does the exhaust need to come off? Its a rusty mess that will end up with sheared bolts if I even look at them the wrong way!
Your exhaust manifold is at the front, the egr is at the rear. It’s not a job I would recommend doing, you are likely to do more damage than good. Besides these suffer with cracked bypass pipes, better to blank and map out for good, the car will run much better.
Yes the £200 cracked egr pipe I've done one before. I thought about mapping it out but its catch 22, I'll still need to remove it to put a blanking plate in
Nope you only need to cap it at the front between the manifold and bypass pipe, it’s just 2 (often seized) bolts
Ah right, just at the front before it goes onto the pipe that cracks?
Is this the correct blanking plate?
Yep that’s the one, and then it will need correctly mapping out.
Interesting, I had the engine out and decided to give the EGR a good clean. It wasn't blocked but still ended up removing quite a bit of soot and the EGR valve is nice and shiny now. Decided to replace the gaskets as well since it's way behind the motor.
That said, I'm in Northern Ireland and may be interested in this EGR delete, anyone know anyone who can map it out?
If you’re happy to send the ecu over then yes I can deal with it. Drop me a line.
Good evening, unfortunately this seller does not ship to Portugal (https://www.ebay.co.uk/itm/121257881612). Can anyone recommend another seller who has the correct part for the 2.2 i-DTEC? Or, if possible, could you provide the measurements, that would be great. I prefer this model, as it does not require undoing everything. Thank you!
Do you have any machinists or engineers near you?
You could simply loosen the pipe and trace the shape with a pen, then get it cut by a laser or waterjet cutter.
I can't imagine it would be expensive.
Hello, Thanks. Maybe I could manage, but I would need the exact measurements so that I don’t have to start dismantling beforehand... I’ve already searched online (eBay, AliExpress) and I can’t find any blanking plate specifically for the 2.2 i-DTEC, like the one that the seller doesn’t ship to Portugal. :confused:
Like this: egr_block_off_plaat_kit_2.jpg
Just remove your little gasket and use as a template to make one with some metal sheet. It’s not difficult.
I know, but I didn’t want to have the car off the road for a few days. I think I’ll have to buy an original gasket and, using that, find someone to make the blanking plate to delete the EGR. (It annoys me that the eBay seller won’t ship to Portugal, which will end up causing unnecessary expenses! Oh well…)
