My 2.4 just started misfiring after a 200 mile trip to down to London. Perfect drive all the way at a very steady pace as it was raining like mad. Get within a mile of where I'm going and I'm sat at a level crossing for 5+ mins waiting for a train to pass. All of a sudden the idle goes lumpy and the CEL lights up.
Arrive at my friends and scan the code and it gives P0303 and a P0300 random misfire. Over the weekend I replace the spark plugs as I knew they needed doing but to no improvement. All spark plugs looked reasonably used but not terrible and there was no sign of oil or anything in or around the holes.
I've also tried swapping the coils over from cylinder 4 to cylinder 3 to see if the problem followed but it has remained the same. Usually when I first start up the engine runs correctly and if I gently raise the revs to around 3k all 4 cylinders begin to fire again. Driving slowly at low revs or idling for a minute and the misfire comes back.
I'm going to do a valve clearance check as soon as this terrible weather passes. Oil consumption is pretty much non existant - I checked before leaving and again at my friends down south and it was right near the upper line and have not needed to top up in months.
I am not sure if the fuel filter has been replaced recently/ever but not sure if that would cause these symptoms. I'm still sort of leaning towards something electrical as the engine kicks back into life as the revs rise.
Anyone got any suggestions?
