freddofrog
won 16.4k on Euro lottery :)
On a partuclar make of French N/A diesel from the 80s/90s, it was not unusual for people to replace the head gasket, and put the timing belt back one tooth out. The engine would run but without any serious symptoms, apart from vibration, loss of power, and reduced mpg. I believe that the valves would not be damaged on that engine, and redoing the timing belt properly would correct the problem.That said I too don't believe that the vibration is the cause of the fuel consumption issue. It could contribute a bit but not that much. I'm still struggling with why this engine is not producing a huge smokescreen.
***uming that if someone has previously worked on Natasha's diesel and put the camshaft one tooth out on the chain, is it also possible for the engine to run without damaging the valves ?
Also, if any 4-cylinder engine runs on only 3-cylinders, you would also get vibration, loss of power, and reduced mpg.
As the Accord engine is a bigger diesel turbo, if the camshaft is a tooth out, or one cylinder is not running properly (poor valve seal) then maybe loss of power may not be so apparent ?
