My car has 150k km.
About the vibration, I didn't drive other Accords before to see the difference. But in comparison to other diesels i drove, the Accord has less vibrations.
Can you be more specific about this vibrations ?
Well it's like the whole car is shaking a little bit and you can feel it everywhere inside and outside of the car. It's something similar like you shake when you are freezing cold =)
If that is the case I think we have the same problem and it is a timing chain.
Anyway we got the chain ordered and will get it changed on Saturday. I've heard from lots of people that chain give lots of trouble, so just to be on the safe side it's better to replace that anyway. And we really believe that it could cause increase in fuel consumption + it will also explain the vibration. So after chain replacement vibration should be gone.
By the way thank you very much for pointing out about the injector correction readings, we did not realised we can do that as well, so today we are removing all 4 injectors + we have 2 left from our friends car, so will select 4 the best ones by correction readings and install them and then I will drive a bit to see how is the consumption like.
My feeling is that we are close to the solution of the problem - Injectors, Chain, Valve
By the way in relation to the valve on the rail - Jon_G that's exactly how we tested that. The thing about this one is - it's really hard to understand how this can affect the consumption BUT if sensor on the rail is faulty and makes too high pressure in the rail + leaking injector, those two factors can cause higher fuel consumption. That is probably what happened to baxy. He fixed injectors than rail and then felt the difference in consumption.
MAF & MAP. Usually if MAP is faulty would show fault on diagnostic but it does not, so do not think that it's the one. MAF - we have compared readings and it doesn't seem to be faulty as well. So we don't think it's a problem. But if injectors, chain and rail will not help we might have to go back to them.
Anyway thanks everybody for the support as it's important not to feel alone. The car will not be sold in any occasion, as we decided
we have to find what is causing the problem.
