Frique
I unfortunately wrote off my 04 Saloon (ex) and now looking a 09-11 Tourer that's not black. I'd prefer the Buran Silver (EX GT) with manual transmission of course. Any advise?
Many thanks in advance
was about to get onto DPFsrichsprint said:Petrol or diesel?
The petrols are fairly bombproof, whereas the diesels have some DPF issues, you dont want to inherit an iDtec with problems.
Also consider an EX model and just add the GT front skirt and side skirts. Holdcroft Honda do good deals on them.
your probably better off with the petrol...... just my opinion but diesels are only benificial if you do 70% long journeysGreasymook said:Thanks for such quick reply lads. You've all have been tip top. Will take all the info on board and hopefully do you all proud
My drama is whether to get Diesel or Petrol. I do a lot of short journeys but have a 20mth old son so expect to start clocking up the miles visiting zoos and the like.
The thing I've noticed is that when you speak to sellers they rarely have receipts and past MOT certificates; just stamps and I've read it makes a difference. So whilst I've seen a few (EX) I haven't even test driven any as yet due to this.
I've never had lpg but I wish I had now due to my Circumstances changing. I met a Honda owner that fits them to any car. He's never had any problems and you get the equivalent of Something like 50 mpg. There was a CRV that had already been converted in the Autotrader. Personally I think that would be an ideal car, especially if you needed the boot space.Greasymook said:How does that work and what are the pros and cons to doing it Jason?
Correct me if im wrong (going on memory) if stand out side of the car and hold the unlock button, the windows will go down and the sun roof will open untill the button is released. if you hold the lock button, everything should close.r3dd3v1l said:this is the research i done before buying mine 8th gen:
* service history is must as you want reasurance that the vehicle and engine has been looked after.
* Check the clutch condition, private or empty road preferably, travel at quite a low speed and floor it in 2nd or 3rd to see if the clutch grips as it should. Also finding a steep hill and doing a simular test.
* Brake pad and disc condtion.
* Engine mounts, have someone in the car rev the engine while you look into the engine bay, the diesel models engine can move around quite alot on initial start up, but any excessive vibrations or knocking on tick over or while driving id walk away.
* Tyre condition e.g tread wear and steering wheel alignment, as this will tell you if the track is out.
* As your getting an EX GT, there is looooooooooooooooooooooooooooooooooooooooaaaaaaaaaaaaaaaaaads of electronic goodnessone of the most important ones is the operation of the sat nav, PLEASE make sure u dont make the same mistake as i did, and buy an accord with a eastern european disc only
make sure both disc come with the car (upto date preferably)
* do you standard checks with the centre console, check the cd player, usb, aux etc all work.
* Check there is sound coming from all the speakers, if not check the settings withing the settings to make sure it all works.
* Check that the service indicator on the dash matches the hard copy service book, if not ask why.
* Correct me if im wrong (going on memory) if stand out side of the car and hold the unlock button, the windows will go down and the sun roof will open untill the button is released. if you hold the lock button, everything should close.
* Check that electric wing mirrors operate correctly via the controls, mirrors move on demand and in the correct direction, mirror units fold in via the button etc.
* with the ignition on or engine on,put the wing mirror selection button to its neutral position, and put the vehicle into reverse (u dont have to be moving) and the left hand side wing mirror should automatically face the floor / slash kurb.
* Hold the boot release on the key fob to open the boot via the fob. it should pop open.
il keep adding to this throughout the day.
