abs sensor stuck in!
Kris81
stockton on tees
Accord executive K24
Hi guys, ive freed of my sticky handbrake today and also tried to change the abs sensor but it has snapped and the wires and sensor are still stuck in ??? How do I get it out ????
Take the wheel hub off, then drill it out, its only plastic so shouldent take a second. Make sure you take the hub off or you may drill in to the hub and damage the magnetic encoder that relays speed to the ABS sensor.
I done mine last week.
Hope this helps
I've done it without removal of hub but you have to be very careful.
