Hi all,
Came across this thread whilst trying to solve my own problem, which has some similarities to this, so hoping someone with more nous than me can steer me in the right direction! Apologies in advance for the long message, just trying to make sure I have covered everything.
I have a 2006 Accord Tourer 2.2 i-CTDi, owned from 2007 as near-new dealer ex-demo. Problems started about a month ago. Car had previously been running fine and I had been driving for about half an hour with no problems, so engine nice and warm. Stopped to drop something off somewhere. After about 20-30 minutes, tried to start the car again and cranked nice and hard (fairly new battery), but just refused to catch. Check engine light came on. Tried a few more attempts, still nothing. Decided to leave it overnight. Following morning, started fine, and although still had CE light, didn’t experience any further problems. Light went out after a couple more runs, so thought no more about it - thought I had inadvertently flooded engine or something.
Then a few days later, approaching home (engine warm again), doing about 25mph, car hesitated or stuttered really briefly. Initially, I thought I had maybe ridden the clutch a bit or slipped on it or something, as I was slowing down for a 20mph zone. Nothing else seemed to happen after that, and no warnings on dash, so again, paid little attention.
Started to get a few more of these incidents of hesitating/stuttering under various driving conditions/speeds, so obviously something brewing. Then earlier this week got another hesitation as I was pulling away from some lights, and a couple of seconds later the engine died and the CE light came on. As I still had some momentum, I tried to use it to bump start the car, and although I got the normal ‘kangaroo’ action, it didn’t start the engine. I pulled over, turned the ignition off, and could not then start the car again. Same as the first time - strong cranking, but no firing. Tried a couple more times - nothing. I waited about 15-20 minutes tried again, and started immediately. CE light stayed on, but otherwise driving OK. Had to stop off after about 5 minutes for a job. About an hour later, car started again and I got home without further incident. CE light went out again after a day or two. By this stage I knew I had to get car looked at, but my normal mechanic is on holiday, won’t be back for a fortnight! Decided to order an OBD Bluetooth adapter to see what was coming up.
incidentally, none of the hesitations have occurred with the engine being under heavy demand. Mostly I was on cruise control, or manually on stable demand. As far as I recall, only the above traffic light hesitation was under acceleration, and that was not aggressive.
Last night, about 15-20 minutes into a drive home, whilst doing about 60mph, engine shut off again, CE light came on. As before, tried to use momentum to bump start car without success, so pulled over. Again, strong cranking, but no firing. Was beginning to wonder if I had a fuel filter problem (due for replacement, actually probably overdue…), so thought maybe a few squeezes of the primer bulb might work. Tried a couple of times, but no change. After about 30 minutes, although CE light still on, started as normal, managed to get home without further incident.
This afternoon, OBD adapter arrived. Seems to work great, but having expected a fuel problem somewhere, was surprised to get the following (in this order):
Car Scanner ELM OBD2
DTC report
Selected brand: Honda
============1==============
P16A4
Raw code: 16A4
ECU: 12
Status: Confirmed
============2==============
P0339
Raw code: 0339
ECU: 12
Status: Confirmed
Crankshaft position (CKP) sensor - circuit intermittent
Crankshaft Position (CKP) Sensor Circuit Intermittent Interruption
============3==============
P0335
Raw code: 0335
ECU: 12
Status: Confirmed
Crankshaft position (CKP) sensor - circuit malfunction
Crankshaft Position (CKP) Sensor Circuit No Signal
So, any thoughts on where to start? Might the governor messages be a false flag as has potentially been suggested in another thread, and I should start with the fuel filter, clear the errors and see what happens? My worry is that this may actually be an ECU problem and I am screwed. However, I am hoping it might just be a dodgy connection or something, given the intermittent message. When it is not hesitating or stalling, the car runs fine. I am happy to try and replace the sensor if needed, though I am guessing it may not be super easy to get to (can’t find a reference for a model VII, only model VI or VIII), but hoping someone can give me a hint!
Thanks in advance!
DTC report
P16A4
Raw code: 16A4
ECU: 12
Status: Confirmed
P0339
Raw code: 0339
ECU: 12
Status: Confirmed
P0335
Raw code: 0335
ECU: 12
Status: Confirmed
Thanks in advance!
