vinyl_tap
Hi All
just wondered if you could give me your advice on my auto height adjust headlights on my 7th Gen 2005 2.4 Exec.
They stopped working about 9 months ago when I had a rear wing repair where an old girl backed her car into mine (drivers side) I took it to my local garage as the lights were pointing at the floor and all they did was manually wind them up :huh:
Anyway I just left it but I want to fix them now - as far as I understand it there are two sensors - one on the rear passenger suspension and one on the drivers front - is that right?
I ***ume that there's some kind of calibration required if bits are changed - is this done through HDS or is there a manual process I can do? I heard that on civics you can short the SCS line and then turn the key three times (while rolling up your trouser leg and turning four times widdershins waving a kipper
) - not sure if the same applies to Accords?
any help gratefully received!
thanks
Bob
thanks
Bob
