Yep easy and no filters. You will only get 30% out from a normal change. If you want to do a full drain and refill then that’s a much more involved job.
So how many litres do I actually need? It says 2.8L at change or 6.3L overhaul. But someone else mentioned 4.2L?Link to ATF replacement procedure, as per ESM: https://mega.nz/file/so0TTJoB#wD2P7B_KmUsRZ0xcHh6GRdWOUvNuSz3w1GR0LgApiqc
The guides on here say to get 3 liters, not sure where you're getting 4.2 from?So how many litres do I actually need? It says 2.8L at change or 6.3L overhaul. But someone else mentioned 4.2L?
