Jon_G said:John - injection timing on a common rail diesel doesn't depend upon the pump being sync'd... it's just there to lift the fuel from the tank and also pressurise the fuel rail... then the ECU controls the injection timing via electrical signals to the injectors.
There is a rotary driveshaft from the passenger end of a camshaft which the fuel pump connects to.
Thanks for that Jon, learn something new every day, PS can this be fitted to a 6D?? L.OL
Agreed but please also check the drive between the low pressure and high pressure sides of the pump. Bosch CP3 pumps, which this is, do have a bit of a reputation for shearing this drive.Jon_G said:I'd want to be really, really sure that the drive shaft/sprocket from the camshaft to the fuel pump ***embly wasn't broken before splashing out on a replacement pump.
