Carl H
I have a 2007 EX diesel with 69k on the clock.
On the motorway at 60-70mph, sometimes if I give it a bootful the engine revs up but the car does not accelerate. i.e. the clutch is slipping. This only seems to happen occasionally. But it will accelerate up 45 degree hills without the clutch slipping, so I'm not sure it's the actual clutch that's the problem.
I've also noticed that the clutch pedal does not feel quite right. It does not always come up smoothly. When I press it down, sometimes it goes down a few inches before there is any resistance. Other times it feels stiffer than others. I'm not totally sure this isn't my imagination.
Could it be that the master cylinder is worn and the piston is binding? Last weekend I greased it (again) to see if that helped and it does seem to have made a difference to the pedal but the clutch slipping issue is still there. With my head in the footwell I noticed that the pedal seems to have some side to side movement when being pressed - is that normal?
