Decky Bates
My clutch has just started squeaking and can be heard from outside the car is there an easy fix or is the master cylinder up the left
Mine also squeaks from the slave cylinder area, mainly on damp/wet days. I have already lubed the link between the slave cylinder and the clutch release fork with no luck. I guess that I might need to disassemble the slave cylinder and lubricate it inside with brake grease.exec said:Mine squeaks aswell, has done since I bought few years ago, it seems to come from the slave cylinder linkage, which looks a bit dry, havent greased it as I dont know what grease to use, cannot find the Urea grease recommended by Honda.
Same, used to always get it on damp/wet or wintery days, but have been getting it this summer when its been hot albeit very humid too. It seems to go away when I have been driving continuously for a fair amount of time. Let me know if greasing the inside works for you.skhell said:Mine also squeaks from the slave cylinder area, mainly on damp/wet days. I have already lubed the link between the slave cylinder and the clutch release fork with no luck. I guess that I might need to disassemble the slave cylinder and lubricate it inside with brake grease.
As for the urea grease, I bought mine from Lings. The local Honda store didn't ever heard about it :unsure:
