Jan Accord
Hi ti all members
i'm new on this forum so first of all i will introduce myself
My name is Jan, i'm 23 years old, i came from Slovenia so my engish is not perfect :unsure: and i drive an accord CN1 executive :wub:
The car is in perfect condoitions but i have a little problem...when i turn the key and the engine is starting up on my speedo it comes a info that says ''check abs system'' ...after few moments when the engine turns on the fault goes away and the car works fine but every time the car reach for the first time ( after turning up ) 20km/h i hear the abs modulator turning on for a very short time...it sound like when you hard braking, and the abs kicks in but only one kick...strange...this happens every time on cold start up and i dond know why but when engine is cold is starting up a little bit harder...slowly...the first thing i changed it was the battery because i thought that loss of power on start up can cause momentaly fault on othes sesnors...but no...it wasn't the battery...warm start up is normal with no problems
i apologize for my english...i know it sucks
any input for the problem is welcome and thanks for reading
