I've noticed that the coolant is going to need changing soon. I was wondering if there is an equivalent to Honda's type 2 coolant or if it just best to use the original product again.
It lasts 5 years and aftermarket long life antifreezes cost similar anyway. I'd suggest changing the radiator drain plug o-ring as well to avoid leaks afterwards.
Use Honda coolant only man, its designed to be used in the system and has the right chemicals, others won't and you will run the risk of issues such as corroding the inside of radiator. A 5 litre bottle is only around £17/18
I did a little search on the internet and stumbled upon this topic from an US forum: http://www.hstuners.com/forums/showthread.php?t=3324. The topic states a few differences with "big brand" coolant manufacturers such as the use of organic corrosion inhibitors. Also it states that the Honda coolant should be silicates and or borates free.
