Tiberious SG
Up until yesterday I was convinced that I should buy the Blistein B12 Pro kit in order to lower my Accord.
My second choice was the BC Coil-overs which I know a lot of the Forum Members are running.
I'm now reconsidering the BC Coil-overs so wondered if anyone can help sway me in either direction here are my pro and cons list for either option:
BC Coil-overs RH Series
Pro's
Con's
Bilstein B12 Pro - Kit
Pro's
Con's
Extra info :
Originally was going to go A-spec route but kit discontinued and unable to find new one,
04 i-cdti exec,
daily motorway driver not track weapon, (yes I know that any lowering + the below wheels are going to reduce comfort)
I have a set of 19" rages to go on later in the summer when current tyres have finished their life.
I'm taking faddys advise and changing all bushes front and rear and checking all links and joints prior to the install
If anybody can help persuade me which way to vote with my cash I would appreciate it, all opinions are welcome.
Pro's
- Recommended by TA Members and alot of other sources
- comes with top mounts and some camber correction
- may be easy than the the Bllstein for my mechanic to install
Con's
- Will have to dial them in to level of lowering and dampening I require.
- Believe that coil-overs have less longevity than spring and damper combo
- slightly more expensive than the Bilstein B12 pro kit (£130 more)
Pro's
- Brand reputation - Bilstein & Eilbach are pretty highly recommended.
- Damper and spring combo are thought of as more reliable and have better longevity
- no adjustments needed as fixed
- cheaper than BC coil-overs
- Monotube design is better than twin tube hence why I'm not considering the Koni SSK
Con's
- May be more difficult for my mechanic to install
- Although I plan to only drop car to around 30mm - to 40mm there is no camber adjustment built into this setup so will probably need extra kit which i might not need with the BC coillies?
- B12 kit comes with uprated Bump stops and sleeves but does not mention top hats /mounts so unsure if original OEM will work
Extra info :
04 i-cdti exec,
