Yanny
Thinking of removing cat and pre cat from my 05 ex diesel accord , will it give me more performance and extra problems . Or is it quite straight forward , I will be doing this with a K&N air filter .
are you planning on removing the cat from the exhaust system?and are you also intending to install a k&n air filter to the diesel engine?? ..regarding the cat on the exhaust,im not sure if anyone has done this to thier diesel :unsure: regarding the k&n air filter to the accord diesel engine have a look as its has been done and discussed,in the end it was found that the diesel engines with after market intake system lose out on low end torque,due to the diesel engines working more on compression rather than combustion, in which the air filter did not make any improvements,apart from a louder turbo swooosh.Thinking of removing cat and pre cat from my 05 ex diesel accord , will it give me more performance and extra problems . Or is it quite straight forward , I will be doing this with a K&N air filter .
OK I see - the ECU is aiming to maintain the spin of the turbo by adjusting the vanes, and it does this by judging the pressure in the exhaust against a set of parameters, so low pressure would equate to low flow therefore close up the vanes to deflect more gas around the turbine and maintain boost. So if you remove the obstruction in the exhaust you would need to re-map the parameters for the VNT controller to allow for the reduced pressure in the exhaust.The Honda ICTDI runs a VNT turbo so the correct volume of boost is always being generated as calculated by the ECU - a wastegate would be pointless. And this is the issue, once you reduce the backpressure (whether we're talking pressure waves or increasing pressure in the exhaust), then the ECU is requesting higher pressures from the turbo to compensate. The net effect is a turbo being forced to work harder.
I'm happy to be corrected on this however, it's my theory (based on some personal experience).
