DIY 6th Gen Rear Brake Howto
AndyB1976
Glasgow
2002 F18B2 CG8
6th Gen CG8 F18B2 Rear Brake Disc and Pad Service​
This is my 6th Gen CG8 F18B2 Rear Brake Howto
Safety, Lifting and Supporting the car.
Put the car in gear, chock the front wheels – if using large bricks be aware of your front bumper becoming crushed as you lift the rear. If you have a large enough jack, use the rear tow hook to lift the end and secure the vehicle with axle stands.
Now the car won't kill you by falling on you also want to ensure that when the job is over the bolts are all tight enough that the car will stop when you need it too. A Torque wrench really is a must for the DIY'er here, braking efficiency and safety is paramount. Ensure these bolts are torqued according to spec.
Also remember you will be handling grease and friction surfaces simultaneously later on. Do not contaminate the friction surfaces of the pad face or the disc itself with any grease.
Tool List
1. Breaker Bar 1/2”
2. Breaker Bar 3/8”
3. Halfords Torque Wrench 3/8” 8-60Nm
4. Pry Bar
5. Ratchet 3/8”
6. Brake Cleaner
7. Spanner 15mm
8. Wire Brushes
9. Sockets 12mm 14mm
10. Impact Driver
11. Laser 1314 Brake Piston Rewind Tool
12. Hammer
13. Clamp (front piston)
14. Strap (for securing caliper)
15. Copper Grease
16. Rubber Grease
17. Safety Glasses
Some duplicate items here,namely the breaker bars and sockets. Not all essential, but its what I used in the process. The procedure is essenitally the same for the fronts, only using a clamp to push that piston in.
Removing the Caliper
First thing to do now the vehicle is secure is to release the handbrake!
The rear caliper is secured by and upper and lower 12mm bolts at 26ft-lb. These two bolt screw into the end of the slide pins, which will likely begin to rotate and twist the slide pin boot. To avoid this hold the slide pin ends with a 15mm spanner and remember to spin the bolt clockwise as you look at it. Habit always has me spinning this anti-clockwise but as you are effectively infront of the bolt rather than behind it just remember the orientation.
Once the 12mm bolts are removed the caliper can be eased off. You might find this a little tight, so a prybar is useful to pry it off. Do not let the caliper fall off the bracket get ready to catch it.
Once the caliper is off, do not let it hang by the hose, tie it up to a control arm or shock coilspring with wire, bungee cord or a strap.
Next the old brake pads come off. Again these might need hammered or pried out. If you are just doing a brake service rather then new pads then take care here not to damage anything.
Slide Pins.
I usually tackle the slide pins at this point. The upper and lower pins are often a little different so just do one at a time not to mix them up. Hold the boot and ease the pin out. You can see here the remnants of the rubber grease from 12mths/5kmiles ago. This year I will keep the grease as is, I want to experiment with more miles and time to see how long the grease holds out.
Otherwise just clean the pins up with a paper towel and regrease them.
Removing the Caliper Carrier/Bracket.
Two 14mm 41ft-lb bolts hold on this bracket
Usually when I'm taking off bolts that have been on for a while I'll go for a 6 sided socket hence the 1/2” impact socket and large 1/2” breaker bar.
Then I'll just spin it off with what's at hand, on this occasion a 3/8ths flexihead ratchet with 12 sided socket.
Removing the Brake Disc.
There should be two disc retaining screws visible. Now this can become a nightmare here or can be quite an easy task. The screws are notorious for stripping. The recommended method is using a manual impact driver.
Set the driver to impact LEFT. My method of using this is to;
Tap the driver and bit slightly into the screw to ensure its bedded in just enough. This is a very light tap or two here, anything more will rotate the bit too soon.
Keep some inward pressure on the driver
Keep a little anti-clockwise pressure on the driver (basically reduce any slop on both axis)
Firmly strike the end with a heavy hammer, don't go overboard let the hammer do the work so to speak.
Now just unscrew both of them and the disc can be eased off
OK, the hard work is now over. I'll begin to clean up the ABS ring and generally all around the hub.
I usually clean the hub up and with wirebrush and cleaner, then dab a little copper grease on it.
Then clean up the carrier, paying attention to where the pads sit.
Then clean up the pad edges that sit in the carrier, note this is the inboard pad with the squealer evident.
Now regrease the pads where they sit in the carrier.
Piston Return
As the handbrake mechanism is built into the caliper, the piston cannot be simply pushed back. The piston needs to be rewound clockwise. You can use large pliers or screwdriver to do this or take the easy option with a specific tool. As I do a brake service annually, this tool is more than affordable and is effortless to use.
Note the notches in the piston, they should run horizontally with the caliper bolt holes in the vertical orientation. The 'key' of the brake pad fits into this notch.
Two metal pins from the tool fit in these notches. You can see the circular rearend of the pin here. If you are just reusing your old pads, two revolutions (720degrees) is usually enough. If new pads are going in then rewind the piston fully.
Reinstallation
….is the reverse of removal
So slip the disc back on, ease up the disc retaining screws. These screws are just handtight.
Secure the bracket back on at 14mm and 41ft-lbs torque.
Replace the brake pads
Replace the caliper with 12mm bolts at 26ft-lb, might be a good idea to hold the pins with a 15mm spanner.
Great write up man. Have some rep points on me ;) .
I've not got a 6th Gen, but +1 for a superb writeup :)
Excellent writeup mate. Appreciate you taking your time to write this.
Absolutely, it's threads like this that make a good forum great. The users and community bringing this much insight and detail to a DIY thread. Keep up the great work mate.
Another great write up and DIY fella thanks for the great effort.
Another great write up man, after my recent failings I'm a bit low on confidence, but the effort you put into doing this write up deserves a bash at it!
May have a few questions for you and others.
Actually first one, is it okay to give the existing brake disc a clean up with brake cleaner? I think mine could do with a freshen up.
Yip...
Brake cleaner is fine to spray on as it evaporates away quickly anyway. The only thing is your disc shouldn't need a freshen up as such, the pad themselves should scrub away surface rust and dirt unless you mean on the non-brake surfaces. My pads and discs are 6.5yrs & 31000miles old in that pic taken just last week.
Don't worry about any failings, you don't know who worked on the car before you also things seize up, rust on etc.
Once you've done it, you'll never look back
