Hi All, not having much luck of late with this car (7th Gen Tourer 2006 iCTDi EX on 67k).. it stranded me on the motorway last Thursday, its now at Newton Honda for diagnostics.
Back story: when the car went in for the new heater matrix, the techs reported that the engine management light was illuminated and when they checked it came up with a crank position sensor fault. They cleared the fault and it didn't come back on the test drive so they gave me the car back with a new matrix and a clean bill of health..
The following day, the engine management light came on again, so I called them up and was advised that there was probably an intemittent fault but as the car was running as normal it was ok to drive but I should book it in for a check up - of course when I got back to the car, the light was off and all was fine.. until Thursday evening.
After a smooth drive through London heading out on the M4, just as I moved onto the the M25 interchange I got some juddering, engine management light on and engine dead.
Parked it up on the hard shoulder - failed to start it after a few attempts and made the usual calls.
Recovery turns up after the usual delay and promptly starts the car on first attempt! But it won't idle properly so he sticks it on the back of the truck and after a bit of negotiating drives me back home.
I fired it up this morning, engine light still on but running as normal - so I drop it in to Honda to beat the snow. They are running diagnostics on Monday.
From my bit of googling - looks like an intermittent CPS failure which is going to cost me north of £300 for diagnosis and replacement... Any thoughts?
Ade
Ade
