invent
hey you was right ! ive checked the glow plugs with the wires, using battery, and all of them was alright !
now im looking for the relay..
If you connect the light bulb up to the glowplug, then it'll tell you if the relay is switching the current through OK.
Seeing as how you obviously understand a bit about electrics then you may as well test the relay before buying a new one.
Already checked the connections and tried to unplug and plug it back. i'll wait for the new relayProbably. I guess a bad connection is also a possibility?
I'd unplug the relay and make sure the connections don't look corroded.
Nobody answered the question...but I will ask another one:JapCar said:It is old thread but I would ask where glow plugs relay is? I mean which one from the fusebox under bonnet?
I did it, the resistance was as I expected (about 1 Ohm) and when installed it , after started the engine in few seconds came on Check System. Recorded error was Glow plugs and after checked new one it was burned... I don't know if the glow plug was cheep fake one, or the resistance generally should be different, thats why I ask here if somebody checked the resistance...It is very easy by multimeter/ohmmeter...F6HAD said:Buy a new one and check it. That's the only way to know.
I can't explain what I see on the diagram...I expected power switch to glow plugs (from GP Control Module) to be connected to any power 12V fuse but on the diagram it goes to ECM... And why glow plugs are for 11V?F6HAD said:I believe the relay is looking for a return signal within a specified time and if it doesn't get it, it throws up a glow plug malfunction error.
My relay is like black ones from the link but didn't noticed yellow dot...wookie said:Glow plug control relay is a separate relay from the fuse box. It should have a yellow dot on the side of it. The early accords had problems with them and they were replaced with a modified unit hence the yellow dot. But they can still fail. I would try a relay unit first.
