Stevie it might be a case of corrosion on the lock.
Try to get someone pulling the lever in the car wile you push in and out on the cover.
If you get it open give it a good spray with WD40
I can get it open by putting a bank card etc. through the gap and pushing the release down. The release does seem a bit stiff to push, I will try greasing it up a bit.
