Full Beam stays on
chesjak
south coast
Accord I-ctdi
When I flash the headlights main beam it doesn't go back to dipped. I have to go under the bonnet and bang the fuse board to release the solenoid. Even if I turn the ignition off, the headlights main beam still stays on.
Has anyone else had this and if so how did you rectify it.
Coming up for an MOT so need to get it srted or it will fail.
Many thanks for any help
What does stop the high beam ?
I would suspect the steering console switch might be behind it, have you had any damp issues in the car ?
F6HAD Richard B I think both your suggestions would solve the problem but not sure how to do it. Exactly where is it and how do I get to it. Also, if I disconnect the fuse box will it cause any electrical problems.
I read somewhere that it could be the Electrical Load Distributor, whatever that is. If it is, how do I get to that also.
If banging the fusebox is solving it then sounds like a sticky relay. Just locate the correct one using the fusebox key printed on the box (or possibly in your owners manual) and simply remove and replace it.
