Full Beam stays on
chesjak
south coast
Accord I-ctdi
When I flash the headlights main beam it doesn't go back to dipped. I have to go under the bonnet and bang the fuse board to release the solenoid. Even if I turn the ignition off, the headlights main beam still stays on.
Has anyone else had this and if so how did you rectify it.
Coming up for an MOT so need to get it srted or it will fail.
Many thanks for any help
What does stop the high beam ?
I would suspect the steering console switch might be behind it, have you had any damp issues in the car ?
I have opened up relays and cleaned contact points. They aren't especially complicated.
Have you tried replacing the headlight relay?
F6HAD Richard B I think both your suggestions would solve the problem but not sure how to do it. Exactly where is it and how do I get to it. Also, if I disconnect the fuse box will it cause any electrical problems.
I read somewhere that it could be the Electrical Load Distributor, whatever that is. If it is, how do I get to that also.
If banging the fusebox is solving it then sounds like a sticky relay. Just locate the correct one using the fusebox key printed on the box (or possibly in your owners manual) and simply remove and replace it.
It's actually not that simple.
The headlight relays are buried inside the Relay Control Module, which is that unmarked sealed box to the right of the engine bay fuse box. Honda treats this as an non-serviceable part, and it looks like it is built into the fuse box itself, but apparently can be separated.
People don't seem to be all that aware of this part, because it rarely plays up. As a consequence, you don't see them for sale all that much. I think wrecking yards sell it as part of a complete fuse box. People who have trouble with this part mostly do not get answers, as far as I can gather from online forums. Yet all Hondas past 2000 seem to have them. They might even be identical between models. IDK, there just isn't much information available.
The Gen 7 Accord/TXS Honda Workshop Manual doesn't even point out where it is located in its parts diagrams, and only mentions the name as part of a test procedure (attached).
Hi Richard B
I was rather thinking that was going to be someones answer. It doe seem that the lights go off when I hit that Sealed Box not the fuse box.
If I have a go and try to take it apart, do you know if it will cause any electrical probs such as damage to other electrical components.
Where did you get that info you displayed by the way. Is it part of a manual somewhere I can get hold of
Regards
From the few examples that can be found online, it looks like the box unplugs with a single multi-connector. I ***ume it is some sort of clamshell body that can be probably be pried apart. From what I gather, the relay control Module controls a lot of stuff.. I can describe what to look for in more detail, but if you've played with electromechanical stuff before it will be straightforward. Let me know.
As long as you are not ham-fisted with this stuff, you shouldn't break anything. You do need to be careful when you are removing carbon from a contact surface that if you use sandpaper you make sure any dust or shavings are blown or vacuumed away from the circuit board(s).
One important thing though. It could be that your problem is caused by running 100W bulbs in your high beams. They should be 55W, and the additional current needed for 100W is what is overloading your relay contacts and causing them to stick. With the level of quality in Honda's components, there is probably some sort of condensor in place to to protect the contacts from sparking, which might not be able to deal with 100W. Just a thought.
Yes there is a workshop manual. It's a database that only runs on Internet Explorer, or Edge in IE mode. I'll drop you a PM.
Also, if you open the RCM, please take photos. No-one has done this, and it would be very useful to see what is going on in there.
I hadn’t realised that. I’ve swapped headlight relays on other cars (most recently one of my old Saabs a few months ago) for the very same issue. I had always ***umed it was the same replaceable item on a Honda. I guess you never stop learning in life!
I would much rather have found a simple, replaceable set of relays.
I hope u/chesjak at least finds some simple through-hole board mounted relays. That, we can fix. The more I think about it though, the more likely it is that at least for concurrent generations, these relay control modules are the same part. Honda insists on replacing the entire fuse box as a fix.
Hi Guys
Sorry to not get back to you before now but have just spent some time in hospital. Up and running now!!!
Yesterday I tried to take the fuse box out.
Unlike yours Richard B my fuse box for some reason has several connects going to it. Can't get to the connectors underneath to remove it because all the cable connected to it are so bl**dy tight, no slack at all.
Any suggestions or is it time to start thinking about moving on. Be a shame, my wife does like her runnabout as she says.
Just comming up to an MOT as well which they say will fail with this problem!!
Regards
Sorry I dropped the ball on this. Rather a lot going on with the family, and our equivalent of MOT for my own car on top of that.
I'd be dremelling the top shell off the Relay Control Module at this stage as you have nothing to lose and everything to gain. You can sikaflex it back into place afterwards. I'm pretty sure all you need to do lightly sand a relay contact, from everything you've told us.
I opened it up as my dipped beam doesn't come on at all and trying to identify the relevant relay. I am aiming to replace the relay if that is the issue at all. Does anyone have a functional or wiring diagram to this unit by any chance?
When looking at the pictures please notice that these are two separate units, one for the diesel (E13) the other one for the petrol EX (E11-M1). Also the petrol one is a bit wet =)
I very much doubt there is a fault in the wiring loom. The control switch on the steering wheel controls two sets of filaments at the front of the bonnet (and both are on with the issue as described)
Have you changed/upgraded any bulbs, or had had a road accident lately ?
If a previous owner has run bulbs that drew much more current than the prescribed 55W bulbs, there could have been arcing in the relay gap. I'd say that Honda would have some sort of spark mitigation to minimise EM emissions, but eg 120W bulbs could have overpowered that. Water ingress or an intermittent short in the wiring is another factor that can damage relays.
I've searched far and wide, but I think that you are the first to share images of the inside.
Identifying the faulty relay is possible a couple of ways, eg. plugging it in and feeling for the click holding a small insulated screwdriver against the body of a relay, or using a thermal camera to see which relay gets warm once the high beams are engaged. Tracing it visually is also possible, I'd suggest marking out a contact trace with a red marker as you ID each bit of the path. But once logic circuits are involved it gets a bit time consuming and again involves powering it up.
Given the relative complexity of the board I'd say that it is shared between models in each generation (or longer.. ) but perhaps programmed differently for extra functionality.. or maybe not, as this can also be done by not having the external components for a particular function. but lights are lights, and e.g a CRC and Accord are pretty much identical in what switches on and off.
It could also be a third party product. (Other boards Honda uses are) If you see any indentifying serial numbers or brand names that could help finding a manufacturer and perhaps more information.. we can also ID the function of chips by their numbers.
Viewing the images of the boards is a bit like looking at the first images of another planet. Quite exciting.. from a nerdy perspective.
I cannot see if the connecting legs / conductors are press fitted into the through-hole board that mounts the relays, or if there is solder involved. Can you remove the PCB once the screws are off?
No road accident and have changed the bulbs about a year ago to honda's spec.
I don't think it is the wiring loom as such, i suspect it is the pcb. Just trying to get a line diagram for the pcb OR a wiring diagram into the fuse box so i can trace back the which connector, which pin is ***ociated with the dipped beam so i can identify the parts on the pcb in the circuit.
I am sorry, i didn't mean to highjack the thread, just wanted to add the pictures. My original thread on the issue is under this link:
Both you and Chesjak are looking for the same solution, to only slightly different problems.
