traderbob86
Hi All,
So im hoping this will be an easy one. I was replacing a suspension arm on my accord and I broke the wire for the ABS sensor.
I have since repaired the wire with heat shrink solder sleeves but my handbrake light is staying on - do i need to clear the fault with an obd scanner or is it the case that the sensor has took further damage?
