Welcome Richard.
I would also recommend having the aircon serviced at Honda. I've discovered very recently that these cars can suffer from aircon pump failure (same engine in my wife's FRV).
Ensure you use genuine Honda parts, especially the plugs.
Also I would go for 5w/40 in that engine.
You don't need to bother with the fuel filter at that mileage, they are not really a servicable item (however it's not impossible to change if you really want to do it, located in the tank under the rear seat).
Transmission fluid should be Honda MTF3, nothing else.
And yes Clutch and Transmission fluid are completely different things. I would recommend also doing the clutch and brake fluid (same fluid type), and then you have a complete major service done.
