gerard_finn200
So as some of ye know I decided to get a set of Eibach Pro springs for the car, got them delivered on Wednesday and yesterday evening I decided to tackle the job in my uncles garage.
The first few steps were quiet easy and none of the bolts were badly seized, having removed the shock and old spring from the car I took the original spring off and clamped the new one, ready to install. To my horror though, the threading on the clamp failed, basically. So leaving me with a shock and spring out, four new springs to be fitted and one clamp, I had to take a trip to Halfords (the only place open at half 7 in the evening) To make matters worse they didn't even stock them!!
So after an hour trawling the town for a garage, motor factors or tool hire I managed to get a set off some man that had his own private garage. I came back and realising the time, decided to put back the one original springs as I didnt want to be out 'till 12 trying to fit a lowering kit.
The start of the job wasn't bad but refitting the shock and spring was torture, I'm sure there's a knack to lining up the notch on the shock and the fork with the bolts in the engine bay, but I didn't have it. I'd say I spent a good hour alone removing it, compressing and adjusting the position of the top mount until it all sat correctly.
Don't get me wrong I'm not here b1tching about it all :lol: I just want to give a word of warning to anyone thinking of doing this job, although it's easy to remove the shock and compress the springs, refitting is quiet difficult and you'd really need a second pair of hands. Also make sure your spring compressor's have a good thread as you definitely don't want them slipping half way through. Plus you really need to do it on a full working day just incase you need to get to a motor factors!!
So after giving the whole job a good "blessing" I packed up and called to my own mechanic on the way home
