Hi guys,
Hope all is well.....been away a while...guess I've been lucky enough to have had no issues with the tourer.
However, I was pushing the old girl hard up a hill on Thursday to get past a flash monkey in his Range Rover and the malfunction light came on....power dropped a little....and I carried on home....turned the engine on and off three times (as per the manual) and the light went off. I did run it low on diesel last time out and wonder if a blockage in the fuel filter might be the issue? I only use OEM filters btw and it's serviced regularly. No issues since....and my local tech is reading the faults for me on Tuesday so I should know more soon,
Anyway, not sure if it happened straight away and I didn't notice, or after but the fan has now stopped working....both on heating and a/c....suspecting the resistor pack may be the problem....seems a common issue....but any thoughts appreciated.
I think the old girl is due some tlc so I'm thinking of replacing the IMRC solenoid too....get an occasional issue with it not pulling away at low revs.
Interested in opinions.
Best wishes
Simon
Best wishes
Simon
