Andy5000
Hi guys,
I think i've managed to fry the ECU in my MK6 Accord, but wanted to check if you guys agree if this is the most likely cause!
The engine light came on last week, after a brief stutter during driving. Following the stutter there were a few micro stutters every now and then, but nothing significant so I made my way home. When I got back (late in the evening) I started Googling the issue and found some bloke on YouTube who was demonstrating self-diagnosing engine light codes on his USA-version accord. By shorting two of the connections, you can get the engine light to flash out a series of short/long codes to indicate what the issue is.
I'm driving the UK version, and when I I found the OBD port i noticed the wiring was different, but in a moment of madness, being too impatient to wait until the morning to take it to the garage, decided I'd give it a go regardless... nothing obvious happened, but when I turned the ignition the engine light was now off. The car will crank, but not start. There is no sound of fuel pump priming. I've checked all 3 fuse box compartments - nothing is blown. I've swapped out the fuel pump relay (found one for £1 at a local scrapyard!). I'm thinking that the ECU is probably dead, given the engine light disappeared completely.
Unfortunately, I cannot find a matching ECU with the same unit / coding part numbers. So I'm now considering sending the unit to an ECU repair company to see if they can sort it out.
If anyone is interested, the part numbers are: ECU: 37820-PVB-E51 / Coding: 742960-1517
Obviously, after I get the ECU fixed, I've got the original fault to fix too, which may or may not be the oxygen sensor. I'll get it diagnosed by a garage properly, if i'm able to get the ECU fixed. Anyway, got a couple of questions I'm hoping someone may be able to help with:
1. Do you guys reckon the ECU is probably the most likely fault?
2. Has anyone tried / had any luck with ECU repair companies before?
Many thanks!
Many thanks!
