Hi Guys,
Took the Tourer in for its annual MOT and was surprised when the tester gave me a fail notice
Basically two issues:
Did a bit of googling and found that the tow bar socket has a fog light cut off built in, basically a plastic pin which the plug pushes in and cuts off the fog....the pins get dirty/corroded and stick causing the fog to be switched of even when the plug from the trailer is not in....an easy fix just strip, clean and lubricate and hey presto!
The front suspension bush however has necessitated a trip to my friendly mech and after getting a discount part from HH I am hoping the labor costs won't be too painful. The mech advised me to buy the whole arm as the saving on labor outweighed the cost increment over just replacing the bush and the other bushes will also be brand new....
On the way to the garage the car developed a squeal from the rear passenger side...interesting the side where the caliper siezed a couple of years back....think it may have caused early failure of the bearing....will report back when I get the car back.
One other recent niggle is that under breaking the drivers seat seems to move forward a fraction? I have heard of issues with the mounting points but wondered if anyone has had similar issues, or is aware of a fix? Anyone taken a seat out?
Simon
- Rear fog not working
- Front lower suspension bush failure
Simon
