johnd
Anyone out there know how the computer senses fuel flow? It needs this to calculate average mpg, along with distance travelled. So I guess there is a sensor fitted somewhere in the fuel delivery system?
True - I just worked out the mpg myself after brimming the tank to see what had been used. Computer displays 58mpg but I've worked out 55mpg. Not a vast difference, but enough!I ***umed it was the ECU knowing the ratings of the fuel pump and working it out from that. That way it would explain the rubbish calculations of the MPG.
So basically none of you know and are all guessing
Yeah, but an educated guess. Having a look around it does seem to be down to the opening and closing time of the injectors and the distance travelled. The fuel used can't be measured anywhere else especially with common rail diesel.
Although the ecu calculations used on most makes of car for mpg seems very inaccurate.
wasn't listening
Haven't seen one fail yet...they do have a bypass system built in just in case the impeller seizes.That would be what I meant by turbine... they must make them pretty durable to work in aircraft!?
surely it must be a transducer...possibly a diaphragm which is displaced with fuel pressure and this displacement is measured ie. more pressure- more displacement of diaphragm- bigger output signalSo what measures fuel pressure?
and Pressure Sensor is not a valid answer :lol: Where is it and what type? A Transducer? Simple switch? High/low limit switch?
Listening to what fella? Bunch of sanctimonious earth mothers - I learnt nothing... Don't panic - sit back and feel the power of dreams :lol:
