toffee_pie
I am a bit OCD with cheacking oil, , i got an oil change in December, the guy in the garage put in castrol 5/30 it was 4 litres, i knew it was not full up but i was fine with it and now last week i decided to top it up, my back yard here is not very even, so basically i have over filled.
its about 200mills above the top mark, not much. I say 200mm as from H to L is about a 1 litre, so half way is 500mm, and my reading is slightly above the top, so it seems maybe 150-200mm above.
Should i worry or let it ride? or drain it? I just took it for a drive earlier, no problems, was about 15minutes, i checked the readings again and the same level.
The car has been good to me, so just seeing what others thoughts are ?
